Cub Crafters Introduces Carbon Cub Kit
In a utility airplane, the power-to-weight ratio reigns supreme, which is why Cub Crafters is making a big deal about its new Carbon Cub kit. Said to weigh 200 pounds less than traditional Super Cubs, the Carbon Cub is designed to accept powerplants from the 100-hp Continental O-200 to the 180-hp Lycoming IO-360.
Cub Crafters says a 160-hp version, certified in the Experimental/Amateur-Built category, can weigh as little as 925 pounds empty. An ELSA version, with the O-200, can weigh as little as 845 pounds empty, according to the company, leaving 475 pounds for people, things and fuel. Select use of composite materials and a simplified wing structure—with half as many parts as the original Piper design—contribute to the weight savings, the company says. A modern cowl design along with a streamlined fuselage also improve performance to "130 mph or more" in cruise.
The kit prices start at $19,995 for the standard fuselage kit plus $19,995 for the standard wing kit and $19,995 for the standard finishing kit. These subkits complete the airplane save for engine, avionics, paint and interior. Additional options include ready-to-cover quickbuild wing and fuselage kits (add $3000 to the wing kit and $4000 to the fuselage kit) as well as a Deluxe finishing kit (add $4000). Cub Crafters can provide the components painted for additional cost. Finally, there is an optional High Gross Kit ($4995) that takes the non-LSA version from 1430 to 1650 pounds maximum gross weight.
With all the quickbuild options, the Carbon Cub will be ready to cover in 120 hours, the company says.
KITPLANES Editor at Large Marc Cook has been in aviation journalism for 23 years and in magazine work for more than 25. He is a 4500-hour instrument-rated, multi-engine pilot with experience in nearly 150 types. He’s completed two kit aircraft, an Aero Designs Pulsar XP and a Glastar Sportsman 2+2.
