New Product: Adjustable Mounting Collars
Stafford Manufacturing offers a wide selection of mounting collars that can be used to attach a variety of devices and accessories onto structural tubing frames without drilling or gouging.
The universal mounting collar features a smooth bore and clamp-style design that tightens securely onto structural tubing and shafts without damaging them, the company says. It has two opposed flat sides with countersunk drilled and tapped holes, and can be easily adjusted using a hex wrench. It’s also capable of withstanding more shock and vibration than radiator clamps and other mounting products, according to the company. The collars come in inside diameters of ¼ inch to 1.25 inches and are made from aluminum, steel and stainless steel with optional PTFE bushings where required. Specials including hex, square or threaded bores are optional, as is chrome plating.
Prices depend on material, size and quantity, and are available upon request. For more information, visit Stafford Manufacturing.
