FatBoy Debuts Throttle Quadrants for RVs
FatBoy Throttle Quadrants of Nashville, Tennessee, is now offering side-mounted throttle quadrants for Vans RV builders. All of the RV quadrants are designed for ease of installation and use, and drop in to all RV side-mounted quadrant consoles. The quadrants and custom throttle- and flight-control grips provide complete hands off throttle and stick, strong and smooth action, locking and tension controlled levers, round and flat top cases with throttle, prop and mixture labeling, according to the company.
Further, FatBoy throttle and flight control grips are custom fabricated with finger knurls, palm swells and comfortable non slip lightweight rubber overmolding with standard four-way and PTT switches, the company says.
For more information, call 615/400-4654 or visit FatBoy Throttle Quadrants.
Avatar
4 Replies to “FatBoy Debuts Throttle Quadrants for RVs”
  1. You can check the web site (www.fatboythrottlequadrants.com) to see which aircraft the throttle quadrants will work on. A news item that ran earlier here also noted that the quadrants can be customized. Andy Hawes is the owner, and you can email him at: andy@fatboythrottlequadrants.com.
  2. I bought a Van's RV8 QB, I would like more information on Throtte Quadrant and support
    THANKS
