New Alcal 2000+ Now Available
Alcor, Inc. announces the availability of the Alcal 2000+ for the calibration and troubleshooting of EGT/CHT/TIT, Type K, J and E systems. The tester can simulate thermocouple output millivolts so that instruments can be calibrated on the ramp or in the shop. The Alcal 2000+ will also receive a millivolt input while testing Alcor and other thermocouples installed in its special heater for accurate analysis at operating temperatures.
Other features include:
- Redesigned Pelican case with removable lid for use in any environment
- Internal carrying handle for transport with or without the lid
- Additional EGT/TIT heater that accepts competitors’ larger probes and tests both digital and analog systems (FAA/PMA not required)
- Easy access to the fuse and 9-volt lithium battery for quick replacement
- All the features of the Alcal 2000
- One-year warranty
The price for the Alcal 2000+ kit is $3250.00.
For more information, please visit www.alcorinc.com, or call 800/354-7233.
Avatar
One Reply to “New Alcal 2000+ Now Available”
  1. Sure, tin cans and string will work, but a cell phone/computer/iPad is a whole lot better!!
    The Alcal 2000+ is much safer, easier, and is the most accurate method of troubleshooting thermocouples and entire EGT/TIT/CHT systems. Its heaters will not diminish the longevity of your probes, which is why the use of a blowtorch is not recommended.
    Also, you can't test or re-calibrate instruments with a blowtorch, can you?
    This system is a must have for mechanic shops, colleges offering aviation maintenance programs and FBOs to name a few!
    Thanks for posting!!
