Safe Flight Instrument's New AoA for Experimental Market
SCX_APPROACHSafe Flight Instrument Corporation announced at AirVenture 2014 at Oshkosh, Wisconsin, the new SCx angle of attack system for experimental aircraft. The system uses a lift transducer that--unlike other AoA systems--provides real-time output of the stagnation point on the aircraft wing and converts it to angle of attack.
Safe Flight says wing-mounted transducers have advantages over differential pressure transducers which can be less accurate in low airspeed and slip conditions. Moreover, the lift transducer sensing the stagnation point change has been utilized in primary stall warning systems for nearly 70 years.
The leading edge sensor sends AoA data to a glareshield-mounted indexer/computer display which provides a flashing red LED output as the aircraft nears the stall. There's also an audio output to warn of increasing AoA. The indexer has a sliding reference marker that allows the pilot to change the focal point, providing indication for best rate and angle of climb, best short field approach and best cruise when flying into a headwind or tailwind.SCx_leading_edge_brief
The system, which weighs roughly 10 ounces, can operate on either 14 or 28 volts input voltage and sells for $1495. Customers at AirVenture 2014 will receive a $200 show discount.
The system can also be purchased online at www.safeflight.com
Larry Anglisano
Larry Anglisano is a regular Kitplanes contributor and AVweb's Avionics and Features editor. With over 25 years of experience as an avionics technician, Larry holds an FAA Repairman certificate and is an active pilot. He's also the Managing editor of sister publication Aviation Consumer magazine.
One Reply to “Safe Flight Instrument's New AoA for Experimental Market”
