More Time to Comment on FAA Hangar-Use Policy
HangarAgency grants extension requests from EAA, CAF, others
September 2, 2014 - The Federal Aviation Administration will allow an additional 30 days to comment on its proposed hangar-use policy under an extension granted Tuesday following multiple requests from the GA community.
EAA early last week submitted a request for a 60-day extension to the comment period based on the intense interest the policy had generated in the general aviation community. Other extension requests were submitted by the Commemorative Air Force (CAF) and by U.S. Rep. Sam Graves (R-MO).
"EAA felt that more time should be granted for the public to weigh in on this important issue for those who have hangars on airports that receive federal grant assurances,” said Sean Elliott, EAA’s vice president of advocacy and safety. “Although we had asked for a 60-day extension, we will continue to get the word out to make sure those who want to submit comments do so within the extra 30 days allotted.”
As EAA reported last month, many people thought that FAA already had a comprehensive airport hangar-use policy at facilities that receive FAA airport funding. That is not the case. The proposed policy is intended to prevent non-aeronautical uses that eventually work against airports and hurt their long-term preservation for intended aviation use. A clear policy guides airport managers and users to what is allowed and what isn’t. It also protects activities that some airport managers might choose to attempt to ban or curtail, such as the construction of homebuilt aircraft or restoration projects.
While EAA will submit its official comments near the final deadline, its comments will focus on three areas that need further consideration or redrafting:
  1. EAA is urging the FAA to replace the term “final assembly of aircraft” as a protected aeronautical use to “active assembly of aircraft.” Prior to this policy draft, homebuilders had no protection as an allowed aeronautical use, although some builders had “gentlemen’s agreements” with their local airport management. EAA believes this policy is the perfect opportunity to formally recognize — for the first time — all active aircraft building and restoration as a protected aeronautical use of hangars.
  2. EAA recommends that the section explaining allowance for incidental non-aeronautical items in hangars be more defined than “an insignificant amount of hangar space.” EAA contends that once an individual hangar reaches its designated capacity of aircraft as a protected aeronautical use, the remainder of the space should be available for non-aeronautical items. This change would prevent overstrict interpretation of any FAA policy by the agency or local airport management.
  3. Inclusion of community-based, not-for-profit aviation organizations to own and maintain hangars on airport property. This would continue the status of facilities such as EAA chapter hangars and other aviation-related organizations on airport grounds as an acceptable aeronautical use. These facilities and the sponsoring organizations provide an avenue for building strong local aviation communities, as well as a base for providing aviation safety information and inspiring the growth of aviation for people of all ages.
"We hope the FAA recognizes that this should not be a one-size-fits-all policy, as what may be advisable hangar policy for large metropolitan commercial airports is not practical or desired for smaller airports that are local education and social hubs as well as an air operations facility,” Elliott said. “Certain activities still need to comply with local codes and ordinances such as fire codes and commercial-use restrictions, among others.”
Elliott also noted that FAA’s airport grant assurances are a two-edged sword: Federal funding of local airports and the rules associated with the use of those funds are often are the only thing that keeps local governments from unilaterally closing a local airport on a political whim or curtailing various personal and recreational aviation facilities. However, as with any grant issuer, public or private, the money can come with rules attached as to how the money can be spent and the assets they for can be used. EAA’s goal is to ensure the grant assurance permit the aeronautical activities while protecting airports we need and love.
One Reply to “More Time to Comment on FAA Hangar-Use Policy”
  1. I have friends, very active in building their aircraft, who would be denied a building space if the FAA were to not allow "active building" to continue.
