Update: Precautions for Jabiru Powered Aircraft
CASA_LogoThe Australian Civil Aviation Safety Authority will place a set of precautionary operating limitations on aircraft powered by Jabiru engines. This is a revised set of revisions from those originally published, and will allow the use of Jabiru-powered aircraft by student pilots, something not allowed in the proposed restrictions presented over a month ago.
These precautionary limitations follow a high number of Jabiru engine failures and power loss incidents, some of which resulted in aircraft forced landings.
More than 45 Jabiru engine failures or in-flight engine incidents have been reported in 2014, with CASA recently becoming aware of incidents in previous years.
Problems with Jabiru engines include failures of through bolts, flywheel bolts and valve train assemblies, as well as cylinder cracking.
The failures affect a range of Jabiru engine models and have occurred in aircraft used in different flying activities, although many have been reported in aircraft used for flying training.
CASA is currently working with Jabiru and other stakeholders to identify the causes of the engine problems and to implement appropriate solutions.
Photo: Jabiru
Photo: Jabiru
Causes being investigated include design and mechanical issues, how aircraft are flown, and maintenance-related issues.
While this investigative work is ongoing, the precautionary limitations are primarily intended to reduce risks for people on the ground and trainee pilots flying solo. The limitations also ensure that trainee pilots flying solo and passengers understand and accept the risk of a Jabiru engine failure.
The limitations:
  • Restrict flights to day time under the visual flight rules
  • Require aircraft to be flown so they can at all times glide clear of a populous area
  • Require passengers and trainee pilots flying solo to sign a statement saying they are aware of and accept the risk of an engine failure
  • Require trainee pilots to have recently and successfully completed engine failure exercises before solo flights.
CASA consulted with the aviation community on the Jabiru limitations, receiving more than 630 comments. Many pilots maintained they had the right to accept the risk of engine power loss and argued that this right should be extended to passengers and trainee pilots.
CASA revised the proposed limitations after taking account of the consultation comments and other relevant information, and considers that the limitations now to be made appropriately manage the safety risks.
A copy of the limitations. The limitations must be registered by the Australian Government Office of Parliamentary Counsel, at which time CASA will publish a further notice stating that the limitations are in force.
One Reply to “Update: Precautions for Jabiru Powered Aircraft”
  1. Please be aware that CASA are an IRS-like wildly over-zealous government agency who are renowned for their incompetence and despised by every pilot and aviation body except the major airlines that they cozy up to. I have no connection to Jabiru but there is more than meets they eye and it has generated a huge controversy; CASA have refused to release the data they based this decision on for a start.
