Aircraft Spruce Announces Avionics Wire Harness Shop
Aircraft Spruce has a harness assembly shop providing avionics wire harnesses for the experimental market ranging from single avionics units to custom coax cable assemblies to complete panel wiring systems. Aircraft Spruce harnesses are all professionally assembled and labeled neatly allowing for easy installation. Although many of the harnesses are standard and stocked on the shelves for same day shipping, Aircraft Spruce also offers their customers custom made harnesses to specific lengths for each wire needed during installation. When you start working on your avionics panel, you can rely on Aircraft Spruce’s expertise and support for all of your harness needs.
avionics-shop
For more information, please call the Aircraft Spruce Avionics department at 800-826-3160 or visit www.aircraftspruce.com
