Dynon Avionics and ForeFlight add Wireless Mobile Device Connectivity to SkyView System
SkyView_ForeFlight_Flight_Plan_Transfer_Wi-Fi_web_lowDynon Avionics partners with ForeFlight to bring wireless mobile device connectivity to its SkyView System
Dynon Avionics announced a partnership with ForeFlight that brings mobile device connectivity to its flagship SkyView avionics system. Enabled via a new Wi-Fi Adapter, SkyView pilots can now transfer flight plans between devices and send SkyView's GPS and attitude information to ForeFlight Mobile.
Seamless Flight Planning
SkyView pilots can now plan their flights at home using ForeFlight Mobile’s comprehensive flight planning features. Once at the airplane, they’ll save time by sending the planned route to their SkyView system via Wi-Fi. Flight plans sent from ForeFlight can be edited on SkyView and flown by the SkyView Autopilot. Pilots can also transfer updated flight plans between the devices at any time.
Wi-Fi Adapter for SkyView
SkyView to ForeFlight connectivity is enabled by a new Wi-Fi Adapter for SkyView that is installed in any of SkyView’s USB ports. The Wi-Fi Adapter costs $35 and can be purchased from Dynon Avionics dealers or Dynon directly. One is required for each SkyView display installed in an aircraft, maintaining system redundancy. Once configured, ForeFlight connects to SkyView through a secure WPA2-protected Wi- Fi link.
Support for the Wi-Fi Adapter is already built into the recently-released SkyView 12.0 Software. In addition to Wi-Fi and ForeFlight connectivity, SkyView 12.0 has over 40 new features and  improvements, including Autopilot Auto-Trim, OBS Mode, customizable aircraft icons, and a new optional in-air magnetic heading calibration.
SkyView-ForeFlight_iPad_Panel_Picture
WAAS GPS and SkyView Attitude for ForeFlight
Customers also benefit from SkyView’s built-in WAAS GPS, which can drive aircraft position in ForeFlight. This is great for those with Wi-Fi- only iPads, and provides an additional high-availability GPS source for GPS-equipped devices.
When connected to SkyView, ForeFlight’s attitude indicator is driven by the same IFR-capable ADAHRS installed in every SkyView aircraft. This allows your ForeFlight attitude indication and Synthetic Vision display to show the same depiction for the best possible in-flight situational awareness.
WiFi Adapter for SkyView
Getting Started
Wireless connectivity between Dynon SkyView and ForeFlight requires  SkyView 12.0 Software, a Wi-Fi Adapter for each SkyView display, and a ForeFlight Mobile Pro subscription. Instructions for configuring and using these features are in the updated SkyView System Installation  Guide and Pilot’s User Guide.
For additional information, visit the Dynon Avionics website or  www.ForeFlight.com.
A video that demonstrates SkyView+ForeFlight features can be found at https://www.youtube.com/watch?v=RK87NDaMtvY.
A PDF brochure and more information about The New SkyView™ is available at http://www.TheNewSkyView.com.
