Aerox Aviation Oxygen Systems to Provide Free Oxygen Refresher at Oshkosh
ProO2 family
Aerox® Aviation Oxygen Systems will be providing a free Oxygen Refresher during the EAA Air Venture in Oshkosh, Wisconsin   July 20 – 26, 2015.
Should you be feeling a bit tired, sluggish or just in need of an energy boost, please visit the Aerox Aviation Oxygen Systems Booth Number 2130 in Exhibit Hangar B, Aisle B for a quick refresher and learn about the benefits of supplemental oxygen for flight.
Oxygen, essential for human life, is abundant at ground level but diminishes as flight levels increase, necessitating the requirement for supplemental oxygen in the upper flight regimes.
Also on display during the 2015 EAA Air Venture will be several unique products designed by Aerox engineers to improve the flying experience of both the pilot and passengers.
Compact and exceptionally light, Aerox Portable Oxygen Systems can be put together to meet customers individual requirements and are ideal for pilots that frequently rent or use aircraft that are not equipped with built in oxygen systems. The Aerox PrO2 – 2, PrO2-4 and PrO2-6 Personal Emergency Oxygen Systems provide take anywhere convenience and safety at a reasonable cost. The systems are designed to deliver oxygen based on a cabin pressure of 25,000 feet and will flow oxygen at a predetermined rate from 17 to 60 minutes depending on system configuration to allow descent to a safe altitude where you can breathe normally under the conditions. The larger systems can be designed for two users.
Simple to use when needed, just pull the mask and don.  The motion of pulling the mask pulls a cable to activate the flow of oxygen. The systems come with aluminum DOT-3AL cylinders with no life limits and require a 5 year recertification.
If you can carry a soft drink can, you can carry the Aerox PrO2 Personal Safety System.
Aerox also offers a complete line of FAA-PMA (Parts Manufacturer Approval) cylinder assemblies available as direct replacements for most aircraft. Available in either Kevlar® composite fiber wrapped (5 year hydrostatic tested. 15 year service life) or 4130 steel cylinders per DOT 3HT and TC-3HTM (5 year hydrostatic tested. 24 year service life).  Manufactured and cleaned specifically for oxygen service, Aerox cylinders range in a number of sizes and capacities depending on the original equipment specifications. Complete cylinder and valve assemblies are also available.
Aerox also offers other emergency system options as well as a full line of portable and built in oxygen systems.
