Kitfox Cutaway on Display at Oshkosh
The wing leading edge tube has also been cutaway to show the strengthening insert. It is a 5' I-beam insert put in the load-bearing spars of all four wing spars.
Kitfox Aircraft set up a cutaway of a complete airplane. This provides an opportunity to see a Kitfox skeleton that a finished product doesn't offer. The company is also displaying the wing showing the stages of covering steps in the Poly- Fiber process.
Kitfox cutaway
The completed side.
The "open" side of the plane.
Kitfox cutaway
Two-part glued joint connecting winglets and ribs to wing spar
Kitfox provide the Poly-Fiber system for covering the wings with their kits but will give a price break to builders who want to use one of the other systems.
Kitfox cutaway
From left to right, raw fabric with reinforcement tape before rib stitch, pink poly brush section with stitching, finished tape over stitching, silver UV poly spray, and white poly tone top coat paint.
Kitfox-Cutaway-Oshkosh-003
Kitfox-Cutaway-Oshkosh-002
Kitfox-Cutaway-Oshkosh-004
Kitfox-Cutaway-Oshkosh-005
Kitfox-Cutaway-Oshkosh-006
Kitfox-Cutaway-Oshkosh-007
[sc:ad180]
2 Replies to “Kitfox Cutaway on Display at Oshkosh”
  1. The "cut-a-way Kitfox" looks great and should seal the deal for anyone considering the quality of design, kit components, ease of construction and company support when choosing a kit project. Nicely done again Kitfox Aircraft.
    Thank you Kitplanes for unveiling it first.
  2. Very nice, I'm sure this will quell the concerns of a person on the fence, because of concerns with the Build Process. The Kitfox Kits are well designed. I wish I would have been able to see the display. John & Debby are doing a great job with a great airplane.
