Test Mule PSRU
Test mule prop speed reduction unit (PSRU)
Here's an interesting idea, a test mule propeller speed reduction unit. A very wide belt tension adjustment range allows the installation of almost any drive pulley diameter, thus many different reduction ratios (and matching propellers) can be test flown without major modification.
A similar system with a limited adjustment range may be available at a later date.
Dan Horton
Dan Horton says he is "just a homebuilder." He has been a pilot more than 30 years and currently flies a custom RV-8.
