Mygoflight’s New Ultrathin Ipad Panel Mount—Many Possibilities for Experimental Aircraft Pilots
MYGOFLIGHT, maker of premium iPad and tablet gear for pilots, announced the release of their new UltraThin iPad Panel Mount. This new product is available for purchase now.
Going beyond the limits of traditional iPad mounts, the UltraThin iPad Panel Mount™ turns your instrument panel into the ultimate iPad docking station. Other products require a large hole cutout in your panel this mount does not, saving time and money. The purpose of this secure the iPad in a traditional avionics space while making it easy to power and view.
MYGOFLIGHT’s UltraThin iPad Panel Mount™ system is purpose built for aviation and the rigors of the cockpit environment. This mount is pilot installable and crafted from aviation grade aluminum, it is strong, light weight and has a secure and ergonomic feel.
No large cutout required. Maintains integrity and strength of the panel. The UltraThin iPad Panel Mount is mounted on the vertical surface of the panel using four screws for maximum security and reliability. An alternate mounting method uses VHB adhesive to secure the mount to the panel.
Future-proof. Upgrade to new iPad without having to re-drill. Patented design keeps the mounting holes in the same place forever (for same screen sized iPads). When you upgrade to a new iPad of the same screen size, future UltraThin iPad Panel Mounts will utilize the same hole configuration so you do not have to drill additional holes in your panel.
Keep your iPad cool. As they are being used, iPads generate heat that can affect performance – resulting in a high-temperature shut down when you might need it most. The UltraThin iPad Panel Mount was designed with cooling in mind. The open back of the UltraThin iPad Panel Mount allows you to create airflow to cool the iPad by cutting two small vent holes in the panel. The UltraThin iPad Panel Mount can be used with a 5/8" air hose connector, allowing you to attach it to a standard avionics cooling fan.
Keep the iPad charged. The UltraThin iPad Panel Mount has a power cable slot that allows you to keep your iPad charged while mounted on the panel. The UltraThin iPad Panel Mount comes with a 90° lightning cable to keep the iPad charged.
For more information, visit www.MYGOFLIGHT.com. To contact MYGOFLIGHT,  mail info@MYGOFLIGHT.com or call 303-364-7400.
