Portable Oxygen System Show Special
Shaw Aerox® Aviation Oxygen Systems will be offering all portable oxygen systems at 20% off the list price for portable oxygen systems purchased during the Sun n Fun Show in Lakeland, FL April 4 – 9, 2017.
Included in this promotion are a free oximeter and free lifetime oxygen refills as well as a 50% discount on the purchase of a seatback carrier pouch.
Please visit the Shaw Aerox Team and learn more about aviation oxygen systems at Booth A-098 in Hangar A. While there, take advantage of our free oxygen boost to refresh and invigorate yourself for the activities of the show.
The Shaw Aerox PrO2 –2, PrO2-4 and PrO2-6 Personal Emergency Oxygen Systems provide take anywhere convenience and safety at a reasonable cost. The systems are designed to deliver oxygen based on a cabin pressure of 25,000 feet and will flow oxygen at a predetermined rate from 17 to 60 minutes, depending on system configuration, to allow descent to a safe altitude where you can breathe normally under the conditions. The larger systems can be designed for two users.
Simple to use when needed, just pull the mask and don. The motion of pulling on the mask pulls a cable to activate the flow of oxygen. The systems provide aluminum DOT-3AL cylinders with no life limits and require a 5 year recertification.
If you can carry a soft drink can, you can carry the Shaw Aerox PrO2 Personal Safety System.
Shaw Aerox® Oxygen Systems, Inc. designs and builds innovative, high-duration oxygen systems made specifically for the aviation industry. Since 1981, pilots and passengers around the world have depended on Shaw Aerox® O2 aviation masks, cannulas, cylinder tanks, portable oxygen and emergency oxygen systems to keep them healthy, alert and safe in the air.
For more information about any of our products or to learn more about our custom system design capabilities, please visit www.aerox.com, call 1-800-237-6902 or email Aerox@aerox.com
Shaw Aerox LLC has passed our ISO9001:2008 Stage 2 audit. The auditors (CIC Management) have confirmed to the registrar (DAkkS) that Shaw Aerox LLC have an acceptable Quality Management System and should receive ISO9001:2008 accreditation. Shaw Aerox, LLC is unique among its peers in being the only oxygen system provider so accredited.
Shaw Aerox, LLC also offers other emergency system options as well as the full line of portable and built in oxygen systems.
As the originator of high-duration oxygen systems, Shaw Aerox® continues to lead the industry in research and development of new products and innovative systems that deliver the performance, durability and comfort demanded by aviators around the world. From oxygen system accessories and retrofit solutions to cannulas and portable oxygen systems, pilots and passengers around the world have depended on Shaw Aerox® products to keep them healthy, alert and safe in the air.
