Jim Agua's RV12
N696VA is an RV12 built as an EAB. The plane took four and a half years and I logged 1900 hours in the build log. I've only flown it a couple of hours now but I just love this little plane. It's quick and nimble and performs very well.
I painted the plane prior to final assembly because I knew that once I had it flying I wouldn't be able to part with it and I didn't want to take it apart again. (I still take it apart quite a bit.)
The plane flies hands off straight and level and just jumps off the runway. The SkyView is a pretty awesome piece of hardware / software and I'm learning more about it everyday.
Thanks to my wife Misa for all her support in this project.
3 Replies to “Jim Agua's RV12”
  1. Thanks
    Would Kitplanes publish definitions of all of the acronyms used in each article? Or, perhaps, a glossary column of all aviation acronyms somewhere in the magazine? Sure, I can look them up---but where? As "only" an occasional private pilot, there is no way I can remember all of them.
    Thanks in advance.
