Lift Monitor System Available from Aircraft Spruce
All angle of attack instruments, including the LIFT MONITOR, sense the aircraft's ability to sustain lift regardless of airspeed, pitch angle, G-force acceleration, gross weight, temperature, or barometric pressure. However in addition, the Lift Monitor from Lift Management, LLC is specifically designed as an affordable tool for developing pilot skill and confidence in handling the aircraft you are flying today as opposed to the one you were trained in or recently sold.
The intuitive broad spectrum analog display clearly shows lift currently experienced by the aircraft as well as subtle trends to which you can instantly respond. Please visit www.aircraftspruce.com for complete description and specifications.
One Reply to “Lift Monitor System Available from Aircraft Spruce”
