Scout ADS-B
A pocket sized, dual-band ADS-B receiver has just been released by ForeFlight called "Scout."  This may be one of the smallest off-the-shelf solutions available for inflight weather and traffic for use exclusively with ForeFlight's mobile mapping software.
Dual ADS-B antennas are integrated into the casing and the unit is attached to the aircraft window with a suction cup mounting system. There is no software to download, nothing to configure--just plug into a USB  power source and it communicates with your ForeFlight  display via WiFi. Available at the ForeFlight  booth or Amazon for $199.
Jon Croke
6 Replies to “Scout ADS-B”
  1. Would I be correct in assuming this is IN only for traffic etc. Surely something this small does not have the power required for transmitting information OUT or does it?
  2. Selling like pancakes? They better be serving them with REAL maple syrup and not that corn-based crap that they're contaminating our gasoline with...
