Shaw Aerox Aviation Oxygen Systems 20% Off During AirVenture
AEROX Portable Oxygen System, 1 User 'A' System 6 Cu Ft
Shaw Aerox® Aviation Oxygen Systems is offering a promotion of 20% off list price for all Aerox portable oxygen systems.  Included in the price will be one oximeter and one seatback carrying pouch during the EAA AirVenture in Oshkosh, Wisconsin, July 24 - 30, 2017.
Shaw Aerox will also be displaying the latest in Oxygen System Technology with several unique products designed by Aerox engineers to improve the flying experience for both pilot and passengers at the Shaw Aerox Aviation Oxygen Systems Booth, Number 2080 in Exhibit Hangar B, Aisle D.
Oxygen, essential for human life, is abundant at ground level.  As flight levels increase, atmospheric pressure decreases necessitating the requirement for supplemental oxygen.
Also, during the Show if you are feeling a bit tired, sluggish or just in need of an energy boost, please visit our booth for a quick oxygen refresher to help you get through the day.
Shaw Aerox Portable Oxygen Systems , which are compact and exceptionally light, can be put together to meet customers' individual requirements and are ideal for pilots that frequently rent or use aircraft that are not equipped with built in oxygen systems.
The Aerox PrO2 - 2, PrO2-4 and PrO2-6 Personal Emergency Oxygen Systems provide take anywhere convenience and safety at a reasonable cost.   Multiple configurations depending on number of pilots and passengers can be provided to suit your needs.  The systems are designed to deliver oxygen based on a cabin pressure of 25,000 feet and will flow oxygen at a predetermined rate from 17 to 60 minutes depending on system configuration to allow descent to a safe altitude where you can breathe normally under current conditions.
Simple to use when needed, just pull the mask and don.  The motion of pulling the mask pulls a cable to activate the flow of oxygen.   The systems come with aluminum DOT-3AL cylinders with no life limits and require a 5 year recertification.
If you can carry a soft drink can, you can carry the Aerox PrO2 Personal Safety System.
Shaw Aerox also offers a complete line of FAA-PMA (Parts Manufacturer Approval) cylinder assemblies available as direct replacements for most aircraft.
Available in either Kevlar® composite fiber wrapped (5 year hydrostatic tested with 15 year service life) or 4130 steel cylinders per DOT 3HT and TC-3HTM (5 year hydrostatic tested with 24 year service life).
Manufactured and cleaned specifically for oxygen service, Aerox cylinders are offered in a number of sizes and capacities depending on the airframe's original equipment specifications.  Complete cylinder and valve assemblies are also available.
Shaw Aerox also offers other emergency system options as well as a full line of portable and built in oxygen systems.
For more information about any of our products or to learn more about our custom system design capabilities, please visit www.aerox.com, call 1-800-237-6902 or email Aerox@aerox.com
