MGL Avionics 2-1/4" Vega Series
MGL Avionics released its Vega Series of 2 -1/4" Singles for Experimental and Light-Sport Aircraft.
The Vega range consists of twelve 2- 1/4" color display aviation instruments. Using a high-resolution backlit color graphics display, these instruments provide excellent daylight readability, even in direct sunlight. Each instrument includes a rotary control plus 2 independent keys for easy menu navigation and to access specific instrument features. The Vega range has a wide supply voltage range of 8 to 30 VDC with built in reverse- and over-voltage protection. All Vega instruments that have engine monitoring functions have the ability to interface to an MGL Avionics RDAC unit.
The full range consists of AHRS units, Altimeters with VSIs, Airspeed Indicators, Temperature Monitors, Fuel Computers, RPM Indicators and Manifold Pressure Indicators. Each instrument has multiple display and customization options - typical with what you would expect from MGL Avionics.
For more information, please visit: mglavionics.com.
