Large Hydraulics
schweiss hydraulic door
Oh heck--no, it's not an airplane part, and I wasn't cruising along at altitude, trying to stay awake - but it is definitely aviation related, since its part of our new workshop, so let's talk about large hydraulics that require gallons of fluid - and bleeding is a matter of pumping enough fluid to empty a four gallon reservoir. Along with working on airplanes, we've been slowly building a shop addition to our hangar, and part of that addition includes a hangar door big enough to roll airplanes in and out for work. Design restriction meant we needed to keep the building low, so the outside wall could only fit a nine-foot high door.
Using a bifold in that opening would have left us without much vertical clearance, so we went with a single-swing hydraulic from Schweiss, and the door and power-pack have been sitting here, waiting for installation and checkout now since last summer. Well this weekend we finally got to power the system up - and I'm impressed. The kit is wonderfully well thought out - all of the hydraulic lines are color coded, along with the fittings, so it would be awfully hard to put it together wrong, even without the excellent step-by-step, pictorial instructions. Charging the system is a matter of disconnecting the hoses from the two hydraulic cylinders and connecting them together - with a pair of male/male connectors supplied in the kit for the purpose - then running the pump for five minutes to fill all of the tubing. The pump module came pre-filled with fluid, and this step took about half that.
We then continued in the manual, re-connected the "up" line to the cylinders, pressed the button, and amazingly, the door opened up for the first time - with no leaks! The clear plastic bottle safety-wired to the cylinder is there to catch fluid coming out of the return line, and we only saw a couple of drops - very clean. It was then a matter of reconnecting all the lines, lowering the door, topping up the fluids--and we have a working door.
Hydraulics really are easy - no matter their size - if you pay attention to the connections, spin all fittings so they aren't cross-threaded before tightening them down, and get all the air out. Whether they are simple aircraft brakes, more complex aircraft systems--like landing gear--or big cylinders to lift a one-ton door, hydraulics are your friend. Lots of oomph for little complexity. And no leaks--that's priceless.
5 Replies to “Large Hydraulics”
  1. Our new hangers at KBKV have similar door openers. One hydraulic pistons on each end of a 44' door. But opening/closing it took 00:01:30 of holding the open/close button. So I designed a remote control unit, complete with limit switches and pump over pressure protection (in case a car was parked in front of the door!). It's microprocessor based so there's a watch-dog timer in case of power fluctuations, and a timer to protect against limit switch failures. Now I can open/close the door from either the car or airplane...
  2. I have a Powerswing hydraulic door. It gained me about 18” clearance relative to the locally engineered bifold door, but the best part is the speed - It goes upin about 40% of the time of my old door - about 50sec versus 2min 15sec. It is also very well insulated and metal clad to match my hangar interior.
  3. Is there a mechanical safety on these doors if the hose breaks? I suspect that if one hose breaks at one cylinder the other cylinder hose will break for sure since it will be holding the whole door on its own and you can end up with 1/2 of the plane if you are unlucky to be on 1/2 way point of getting out of the hangar.
    Any comments?
  4. Mine has a safety valve that locks the hydraulics in place if pressure is suddenly lost. A critical component for your safety as well as you plane’s!
