Sopwith 1½ Strutter
Sopwith-1-1/2-Strutter
If you want to build a plane that will make you the envy of everyone at the airport and have people lined up to see your plane everywhere you go, KIPAERO has just the kit for you. It is an authentic replica of a Sopwith 1½ Strutter complete with a Gnome rotary engine. The engine is reverse-engineered from a museum piece using modern metals and machining techniques, but otherwise is an exact copy of the original.
The airframe is spruce and ash with brace wires and turnbuckles just like the original. In fact it is built from original Sopwith drawings.
The cost of the complete kit with engine and prop is $182,050. Replica Sopwith Pups and Camels are also available. At this time none are flying but they expect to have a flying example at AirVenture next year.
Even in its unfinished state it is a thing of beauty. Unfortunately the cost will deter all but the most dedicated enthusiast.
David Prizio
Dave Prizio has been plying the skies of the L.A. basin and beyond since 1973. Born into a family of builders, it was only natural that he would make his living as a contractor and spend his leisure time building airplanes. He has so far completed three—a GlaStar, a Glasair Sportsman, and a Texas Sport Cub—and is helping a friend build an RV-8. When he isn’t building something, he shares his love of aviation with others by flying Young Eagles or volunteering as an EAA Technical Counselor. He is also an A&P mechanic, Designated Airworthiness Representative (DAR), and a member of the EAA Homebuilt Aircraft Council.
One Reply to “Sopwith 1½ Strutter”
  1. I just don't get the last line! You imply that to be dedicated you must be affluent. It is like saying one has good taste because one can afford something expensive...i.e. if you can't afford it you have poor taste! Come now, surely you can pick a better wording?
