Light it Up!
LED strip light
How many times have you been working in the depths of your aircraft's fuselage, a flashlight in your mouth, and a work light burning a hole in your trousers (and not providing any light while it was doing it) and wished for better lighting? I have been a cave explorer on and off throughout my life, and I'll tel you what - it was just a good preparation for working in a light airplane's fuselage!
But fret no more! In a recent trip up to Glasair Aviation, I found an idea whose time has come - LED strip lights, intended for use as under cabinet lighting in kitchens and work rooms. These strips of LEDs are available all over the internet as kit of four to six lights, with thin cables to connect them. They are light, small, and compact - perfect for zip-tying or using a spot of velcro to hold them up near the ceiling, out of the way of tools and bodies. You can buy a set for as low as $30 at the local big-box store, and light the entire interior of whatever airplane you're working on. Just mount the switch near where you enter, and you'll have great lighting through the time you spend working back there.
Along with being out of the way, and generating lots of nice white light, they have the added benefits of generating very little heat, and not need to have their batteries replaced. A definite plus when it comes to modernizing your shop.
One Reply to “Light it Up!”
  1. The peel and stick LED light rolls are even better. Cut to length and hook up to 12 volts. Rolls are 16 feet long and about half an inch wide. Very thin. You can use the whole roll or down to about 2 or 3 inches. Just made a 6 foot strip light for our Cub Scout Trailer. Solder connections are better than supplied plug. Best part, you can get a roll for about $11 dollars.
