Experimental Category Aircraft Accident Totals Drop Again
Experimental-Accident-Dashboard-FY2018-thru-September-18-1000Fatal accidents in experimental category aircraft, including amateur-built aircraft, continued their decline during the Federal Aviation Administration's 2018 fiscal year that ended September 30, falling to historic lows.
For the 12-month period from October 1, 2017, to September 30, 2018, fatal accident totals for the experimental category overall, including amateur-built aircraft, racing aircraft, those used for exhibit only, research-and-development, and some types of light-sport aircraft, dropped for the fourth straight year. Total fatal accidents fell two percent, to 44, during the 12-month measurement period ending September 30, 2018. The final figures are nearly 14 percent below the FAA's "not-to-exceed" goal of 51 fatal accidents for that period.
This continues an improving trend of lower fatal accident totals, even with increasing flight hour totals according to FAA data. Since 2015, the FAA has set successfully lower not-to-exceed targets for experimental category aircraft, from 64 in 2015 to 51 this past fiscal year.
"The FAA has challenged our community by lowering the not-to-exceed goal by nearly 20 percent since 2015, but we have met and surpassed that goal. These are historic lows for fatal accident in amateur-built and experimental category aircraft," said Sean Elliott, vice president of Advocacy and Safety for the Experimental Aircraft Association (EAA). "In addition, the FAA in 2010 challenged the aviation community to reduce the accident rate by 10 percent over the next decade. We are proud to say through a focus on safety, that goal was reached in just eight years, two years earlier than anticipated."
Elliott noted that the overall fatal accident numbers remain much lower than other recreational pursuits, such as paddle sports, skiing and snowboarding, and driving all-terrain vehicles.
EAA has worked closely with the FAA and the National Transportation Safety Board on recommendations to reduce fatal accidents, including through participation in the FAA General Aviation Joint Steering Committee that EAA co-chairs. The EAA focus has also included the newly released EAA Flight Test Manual for amateur-built aircraft; the Founder's Innovation Prize competition that seeks innovations to reduce loss-of-control accidents in amateur-built aircraft; and use of an additional safety pilot during initial flight testing in amateur-built aircraft.
"These efforts build upon EAA's longstanding Technical Counselor and Flight Advisor programs, and additional safety materials in EAA's flagship Sport Aviation magazine," Elliott said. "Further reducing the accident totals is a continuing challenge, but one that is foremost as part of EAA's mission to grow participation in aviation."
