How Many...How Much?
When you reach the end of a project (an airplane is never really finished, so we just say "the end of a project"), you begin to ask questions about how many "things" or how much time it took. At least, if you're an engineer you ask those questions - we love to measure things.
Some process improvement wag once said "if you can't measure it, you can't manage it", and there is some truth to that, if you believe in truth at all. And it appears that in this case, we've managed to build an airplane that is ready for inspection!
We opened the boxes for this project on about the 12th of November, and here it is, Valentines day (14 February). So that's roughly 85 days on the calendar. Taking a rough look at the hours spent in the shop, and days away for holidays, travel, and other things, it looks like I averaged about five hours a day working with tools - so somewhere about 425 "contact hours" with the airplane. There are, of course, many more hours spent at the desk looking at manuals, shopping for accessories, and thinking about what I'm going to do when the shop heater has warmed the workspace sufficiently to allow meaningful progress, as opposed to uncontrolled shivering (it is, after all, winter in the northern hemisphere).
As we reach the end of the building phase of the little Subsonex personal jet, here are a couple of pictures that illustrate a few of those trivia statistics you might not think about as you strap into your new airplane.
One way you measure progress on a Sonex kit is by coloring in the completed drawings on the drawing tree. You know when you're done when you reach the point where there is nothing left to check off!
Of course, one question any metal airplane builder is asked is "how many rivets are there in the airplane?" Well in the case of a Quick-build kit, the answer really is unobtainable for the builder (unless they REALLY have too much time on their hands), but I can show you how many rivets I had to pull on this project, because I saved all of the mandrels. Yes, I am an engineer--of course I saved them all!
And finally, how many boxes do you accumulate in the process? Including the boxes the kit came in, and adding the various accessory cartons and the cardboard from several Aircraft Spruce orders, you get a pile about like this. Now its time to go get that box-cutter and start cleaning up this mess...
2 Replies to “How Many...How Much?”
  1. Your shop looks pretty neat! When I see that little air frame with likely a non-spectacular glide ration, I have to say - please be ultra careful in your first flights! Good luck, look forward to stories of glory!
    Reinhard Metz
  2. Looks like he can't go very far in that little speed demon, but boy I bet you he can get there fast! Also, I could be wrong, but I think this has a typical wing for a single seater, so the glide ratio should be fine. And, with a spectacular fuel burn, he can't get very far from the airport, anyway! 🙂
